Vehicle Routing Problem Solver - Silverlight
1310
10-08-2010 04:30 AM
AnilCelik1
Hello All,
I am pretty aware that with given opportunities it's not possible to publish Vehicle Routing Problem Solver(VRPS) into Silverlight application. (Or Am I mistaken?) I just wonder if there is any other option to make it work such as coding a runtime with the help of ArcEngine / ArcObjects? If yes, how?
Or If there is a super-sonic example of the miracle where VRPS and Silverlight comes together?
Or Am I just mistaken about the whole question and its answer? I'm not a developer. I am an Analyst and using all these tools in ArcMap but I support a team of developers and we are a little bit stuck with this problem.
Thank you in advance.
Anil.
PaulLeedham
AnilCelik1
Yes, but this is completely different. I was asking for the tool "Vehicle Rooting Problem Solver" tool under Network Analyst Extension.
Esri Silverlight API supports directly tools such as:
Route
Service Area
Closest Facility
but it does not support
OD Cost Matrix
Vehicle Route Problem Solver
Location-Allocation.
I just wonder if there is an in-direct way to make VRPS in Silverlight.
dotMorten_esri
Esri Notable Contributor
If you can expose this as a GP Tool, you can call it from Silverlight using the Geoprocessing task.
AnilCelik1
Thanks a lot for the tip. But I'm pretty new at whole developing thing and I would be really happy if you know some good source for reading about "exposing a tool".
