using latest version silverlight api and arcgis server 9.3.1
1218
09-27-2010 11:53 AM
MannusEtten
i have a silverlight project with one mapcontrol and one dynamicmapservicelayer.
the url of the layer pointed to a ArcGIS Server 10 mapservice, no problem.
when I change the url to a ArcGIS Server 9.3.1 mapservice no map is displayed.
what did i wrong or is this not supported? in that case, what happened with the rest interface because ESRI introduced again a backward-compatibility issue in this case...
dotMorten_esri
Esri Notable Contributor
MannusEtten
after using firebug to see what happen I saw that there was a cross-domain problem... I added the clientaccesspolicy.xml and problem solved. Thanks for sending the link to the blog!
