Using Itemscontrol and dataBinding
2966
03-30-2012 12:43 AM
JasonWard1
Hi - I use MVVM model and am having trouble changing an app from using the Microsoft Bing Map control over to ArcGIS silverlight map control.
The problem lies in that I use the MapItemsControl property from Bing to display buttons on a map using a template and binding the objects that contain the information I need to build the buttons correctly (they contain images and text and are coloured based on data received).  This all works with the microsoft control - I just need to work out how to do the same thing with ArcGIS.
The problem I am getting is that it appears to fail to bind the ElementLayer.Envelope.  I am using ItemsControl and a local resource template.
I dont seem to be able to find any examples of this - so wonder if I am even on the right path!
Any help would be most appreciated
JenniferNery
ElementLayer.Envelope is an Attached property and therefore support binding. It expects value of type Envelope. You can try the following code:
      xmlns:esri="http://schemas.esri.com/arcgis/client/2009">
    <Grid x:Name="LayoutRoot" Background="White">
        <Grid.Resources>
            <esri:Envelope x:Key="MyEnvelope"  XMin="-117" YMin="34" XMax="-117" YMax="34"/>
        </Grid.Resources>
            <esri:Map x:Name="MyMap">
            <esri:ArcGISTiledMapServiceLayer ID="StreetMapLayer"
                    Url="http://services.arcgisonline.com/ArcGIS/rest/services/NGS_Topo_US_2D/MapServer"/>
            <esri:ElementLayer>
                <esri:ElementLayer.Children>
                    <!--Clickable button-->
                    <Button x:Name="RedlandsButton" Width="20" Height="20" Content="X"
            esri:ElementLayer.Envelope="{Binding Source={StaticResource MyEnvelope}}"
            VerticalAlignment="Center" HorizontalAlignment="Center"/>
                </esri:ElementLayer.Children>
            </esri:ElementLayer>
        </esri:Map>
    </Grid>
JasonWard1
Thanks for your reply - Let me show you some pseudo code as its a litle more complcated that it sounds (to me anyhow!)
I have simplified things to a border.
        <DataTemplate x:Name="example1">
            <Border BorderBrush="AliceBlue" BorderThickness="2" esri:ElementLayer.Envelope="{Binding _envelope}" Background="AliceBlue" />
        </DataTemplate>
<esri:Map x:Name="Map">
      <esri:ArcGISTiledMapServiceLayer ID="BaseLayer" Url="http://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer" />
            <esri:ElementLayer>
                       <ItemsControl ItemTemplate="{StaticResource example1}" ItemsSource="{Binding Path=_BordersforDisplay, Mode=OneWay}" />
</esri:Map>
The observable collection _BordersforDisplay is shown simply below without the notification code OnPropertyChanged()
public ObservableCollection<BorderItems> _BordersforDisplay = new ObservableCollection<BorderItems>();
public class BorderItems
        public string _name { get; set; }
        public Envelope _envelope { get; set; }
As far as I can see, this should work - and I use this same code on a Bing Maps Control using the MapItemsControl in the Map Layer.  Do I need something Similar here?
Thanks again for your help with this.
JenniferNery
ElementLayer.Children is of type ObservableCollection<UIElement>. So in your code, you want just one child ItemsControl? Each child must specify its location through esri:ElementLayer.Envelope. Was your code snippet working for you? Are you getting errors? If you are using Silverlight5, you can debug XAML code and see if the binding statements are resolved.
JasonWard1
I simplified the code from my source - I havent actually tested it in itself, but the principle is the same.
The ItemsControl source is a number of objects where the property _envelope is bound to the ElementLayer.Envelope in the itemtemplate "example1".
I have used this using the MapItemsControl from Microsoft on a bing map - am now looking to transfer to ArcGIS as a client has an in house server they want to use.
After a bit more looking at the error, it would appear that rather than the itemscontrol holding a number of objects that get added as children, that the itemcontrol itself is treated as a child of the elementlayer.  Or maybe it doesnt like the ItemTemplate the way I am doing it.  Am a bit confused as to why - is the datatemplate the correct way to do this?
Thanks again for your help 🙂
JenniferNery
If you want to bind to ElementLayer.Children, I think the following code should work:
     xmlns:local="clr-namespace:Sprint20"
  <Grid.Resources>
   <local:MyUIElements x:Key="MyElementLayerChildren">
            esri:ElementLayer.Envelope="{StaticResource MyEnvelope}"
            VerticalAlignment="Center" HorizontalAlignment="Center" />
    <!--Arrow pointing at Copenhagen from the right-->
    <TextBlock Text="&lt;=" HorizontalAlignment="Right"
         FontSize="15" Foreground="Blue" FontWeight="Bold"
         esri:ElementLayer.Envelope="12.5698,55.6765,12.5698,55.6765" />
    <!--Arrow pointing at Copenhagen from the left-->
    <TextBlock Text="=&gt;" HorizontalAlignment="Left"
    <!-- Red box - No size specified. Envelope guides the size -->
    <Rectangle Fill="Red" esri:ElementLayer.Envelope="0,0,10,10" />
    <!--Editable textbox-->
    <TextBox Width="100" Height="20" esri:ElementLayer.Envelope="40,0,40,0"
       Text="Editable text" HorizontalAlignment="Right" VerticalAlignment="Bottom" />
   </local:MyUIElements>
  </Grid.Resources>
   <esri:ElementLayer Children="{Binding Source={StaticResource MyElementLayerChildren}}"/>
  </esri:Map>
 </Grid>
This local class will allow you to create an instance of ObservableCollection type.
 public class MyUIElements : ObservableCollection<UIElement>
  public MyUIElements() { }
