Using Custom Rest Service - Map Service Legends with AGS 10
936
09-13-2010 09:09 AM
PaulLeedham
I am using the sample posted by Morten and I am recieving the following error on the legend.ashx page when I attempt to point to a service endpoint that has security enabled:
Unable to generate legends: The HTTP request was forbidden with client authentication scheme 'Anonymous'.
Any ideas?
Cheers!
dotMorten_esri
Esri Notable Contributor
Is your service secured? There's plenty of forum- and blogposts on this error if you search for it. Seems to be a WCF configuration issue.
PaulLeedham
Other services on the server are secured but the service I am attempting to point to is not.  Having said that, I think that when you enable security that all services retain some level of security--the service in question is currently granting permissions to "Everyone".
Map Services from 9.3.1 versions of AGS render fine.
