use print sample step by step !!
1675
6
05-31-2012 03:23 PM
YassineEL_JADIDI
hello,
please can anyone help me to use a print sample but i want the steps step by step...because really i didnt know how to use a sample print on my application !
thank you
JenniferNery
You can watch this technical workshop from Dev Summit 2012: http://video.esri.com/watch/1203/advanced-development-with-arcgis-api-for-silverlight-, samples from demo are available here: http://www.arcgis.com/home/item.html?id=ef6a80c07fb84f84a5fe5192221f582c. There is a section there that talks about Printing in v3.0 (see sample: http://resourcesbeta.arcgis.com/en/help/silverlight-api/samples/start.htm#ExportWebMap)
YassineEL_JADIDI
Thank you for your replies,
the problem is the sample printing : [HTML]http://resourcesbeta.arcgis.com/en/help/silverlight-api/samples/start.htm#ExportWebMap[/HTML], don't print the legend with th map.
can i add it ??
JenniferNery
Oh you should be able to print legend using that sample. Advanced session video talks about how that is done. Note that in v3.0 final, you can select any of the pre-defined template other than Map_Only and get legend control without adding any code.
YassineEL_JADIDI
ok i try it but i have a problem of referenced assembly, i need ESRI.ARGIS.Client.Printing.dll , where can i download it please ?
DominiqueBroux
Esri Frequent Contributor
ESRI.ARGIS.Client.Printing.dll  is new with ArcGIS for Silverligh 3.0.
The RC can be downloaded here : http://resourcesbeta.arcgis.com/en/communities/silverlight-api/index.html
YassineEL_JADIDI
i downloaded the version 3.0 and i added the referenced assembly of printing, but it give me the same problem.
