Toolkit for Silverlight from http://esrisilverlight.codeplex.com/releases/view/60154
1101
07-20-2011 05:00 AM
OlegLukyanov
Is new Toolkit for Silverlight 2.2 http://esrisilverlight.codeplex.com/releases/view/60154#DownloadId=252091
localized version?
I try to compile it but version ESRI.ArcGIS.Client.Toolkit 2.2.0649 is not compatible with ESRI.ArcGIS.Client 2.2.0525. How I can add it's resources dll to my solution?
Oleg Lukyanov
Russia
JenniferNery
Are you using v2.2 Final? If yes, you have the correct link for Toolkit. These is a list of What's new in v2.2: http://help.arcgis.com/en/webapi/silverlight/help/index.html#/What_s_new_in_2_2/0166000000m2000000/. Localization resources were included.
OlegLukyanov
Jennifer
I found my mistake. I didn't uninstall previous Toolkit version manually. I can compile my solution correctly after uninstall.
As I understood from help's  "What's new..."  and after compile  XAML source (menu and etc) didn't localize and I need do it myself. Is it true?
PS
I translate menu in FeatureDataGrid To Russian  and  compile  Toolkit. Is it possible to use local. Toolkit in Arc SL Viewer beta 2 ?
Oleg
