tool images / icons
1942
10-06-2011 08:06 AM
GaryBushek1
Does anyone know if there is a repository anywhere that contains common images used in the template apps / code gallery?  Looking for an icon just like the identify icon only with an "a" instead of an "i".  If this doesn't exist and there are tools out there that are commonly used to build these icons, can someone point me in that direction?
Thanks a bunch.
ChrisBradberry
There is directory of png files that you can use in c:\program files\arcgis\DeveloperKit10.0\icons
I use these and change them with photoshop or gimp.
Chris
EzequiasRodrigues_da_Rocha
Hi everyone,
I would like to know if does anyone could help me with the setting of a tool default icon.
I tried to define in the viewer config/tools.xml
<Tool Label="Pan Tool" Icon="
I've tried to use the Default icon property in my .NET tool class
[DefaultIcon("Images/PanTool_B_16.png")]
But the tool always appears with the default icon as you can see in the image i sent.
Any help would be nice
Regards
Ezequias[ATTACH=CONFIG]18029[/ATTACH]
DominiqueBroux
Esri Frequent Contributor
Your question looks related to the Silverlight Viewer. You might get better answer by posting it on the viewer forum.
