ToggleLayerAction
1499
6
05-27-2011 01:00 PM
DaveOrlando
okay I must officially be going crazy,
I found this wonderful little action and low and behold, my layer only toggles on/off
1. after you pan the map, and/or
2. evertime after the first (no need to pan)
anyone else have a similar issue?
<Button x:Name="MTWater"
                                    Style="{StaticResource MenuItem}"
                                    Content="Map Tip Water">
                                <i:Interaction.Triggers>
                                    <i:EventTrigger EventName="Click">
                                        <esriBehaviors:ToggleLayerAction LayerID="FLWaterLines" TargetName="MyMap"/>
                                    </i:EventTrigger>
                                    <!--<i:EventTrigger>
                                        <esriBehaviors:UpdateFeatureLayerAction FeatureLayerID="FLWaterLines" TargetName="MyMap"/>
                                    </i:EventTrigger>-->
                                </i:Interaction.Triggers>
                            </Button>
#plsworkthefirsttimeforonce
DaveOrlando
further,
if I start with the Layer Visible = true, it turns off okay at first attempt.
if I start with the Layer Visible = false, it won't turn on at first attempt until the map is panned.
DominiqueBroux
Esri Frequent Contributor
I didn't reproduce the issue.
I changed this interactive sample http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#LayerActions in order to start with a non visible layer and the layer turns on at first attempt when clicking the ToggleLayer action.
Could you give more infos on how to reproduce this issue?
DaveOrlando
Thanks for checking,
Can you verify with a FeatrureLayer using OnDemand and a MaxResolution set (yes I was below this resolution when I first tryed to turn it on).
<esri:FeatureLayer ID="FLWaterLines" Url="http://***/rest/services/GIS_App_ENG/MapServer/2"
                                       FeatureSymbol="{StaticResource LineWaterBlue}" Mode="OnDemand" OutFields="*" MaximumResolution="3"
                                       Visible="False" x:Name="FLWL" Where="WATERLINETYPE='WATERMAIN'">
                                    </i:EventTrigger>
                            </Button>
Thanks again
DominiqueBroux
I was eventually  able to reproduce the issue with a feature layer but only with 2.1 version. Looks working well with version 2.2.
Which version are you using? If 2.1, could you give a try with 2.2?
DaveOrlando
Thanks for your efforts.
I am meaning to go to 2.2 soon, hopefully this week, so I will repost my findings.
Dave
DaveOrlando
2.2 has cleared this up for us, 😉 great work.
Thanks again.
