The type or namespace name 'DataContractJsonSerializer' does not exist, Json
4862
10-27-2010 08:55 AM
jayshukla
Hi There,
I am trying to run the sample from Interactive SDK and getting this issue, when I build the solution, below is the error that I am getting. I have proper references in place but not sure what I am missing here.
BTW, here is the link for the sample: http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#AddGraphics
using System.Runtime.Serialization;
using System.Runtime.Serialization.Json;
I would really appreciate any feedback.
Jay
Error 1 The type or namespace name 'DataContractJsonSerializer' does not exist in the namespace 'System.Runtime.Serialization.Json' (are you missing an assembly reference?)
        internal static T DeserializeJson<T>(string json)
            T objectInstance = Activator.CreateInstance<T>();
            System.IO.MemoryStream memoryStream = new System.IO.MemoryStream(System.Text.Encoding.Unicode.GetBytes(json));
            System.Runtime.Serialization.Json.DataContractJsonSerializer jsonSerializer =
                new System.Runtime.Serialization.Json.DataContractJsonSerializer(objectInstance.GetType());
            objectInstance = (T)jsonSerializer.ReadObject(memoryStream);
            memoryStream.Close();
            return objectInstance;
        } [/SIZE]
Charles__Jamie_Phillips
You are missing a reference.  I believe the referece is System.Web and that should take care of the issue.  It is one of those gotchas.
StevenMorlock
Namespace:  System.Runtime.Serialization.Json
Assembly:  System.ServiceModel.Web (in System.ServiceModel.Web.dll)
in VS2010, just select it and press F1 for help. this shows you the necessary assembly.
jayshukla
Hi Folks,
Thanks a lot of quick feedback. I was just missing this DLL. Now it's all good to go.
Thanks again.
Jay
