Synchronous and Asynchronous Geoprocessing Services
4760
08-12-2013 05:28 AM
ShaningYu
Honored Contributor
From ESRI Silverlight API Help, it is recommended to use Synchronous geoprocessing services rather than the Asynchronous ones.  If the published geoprocessing service is in the Execution Type: esriExecutionTypeAsynchronous, can it be executed as a synchronous one?  Conversely, If the published geoprocessing service is in the Execution Type: esriExecutionTypeSynchronous , can it be executed as an asynchronous one?  Thanks for your review and feedback.
ShaningYu
Honored Contributor
In AcrGIS Server Manager, there is the parameter selection for Execution Mode: Synchronous or Asynchronous.  Closed.
ShaningYu
Honored Contributor
In publishing a geoprocessing service, is the option for the Execution Type (esriExecutionTypeAsynchronous or esriExecutionTypeSynchronous)?
ShaningYu
Honored Contributor
