styling the OverviewMap component - remove the internal rectangle
767
10-28-2010 04:25 AM
AntonHughes
Hi
I'm wondering if it is possible to remove the internal rectangle from the OverviewMap control?
DominiqueBroux
Esri Frequent Contributor
You can change the style of the OverviewMap by using Blend:
   - Right click on your overview map.
   - Edit template
   - Edit a copy
Then you can edit the UIElement called AOI.
