Standard way to determine spacial reference type
893
06-19-2011 11:50 PM
JH2
Hi all,
My data is all held in Lat/Longs but I'm using Bing maps.  As a result, I use the:
ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator()
call to convert my Lat/Long to position correctly on Bing and then
ESRI.ArcGIS.Client.Bing.Transform.WebMercatorToGeographic()
to convert back the other way.
I'm aware that other map layers don't use Web Mercator, and I was wondering if there was a standard check that should be used when putting data onto a map e.g.:
if (MyMap.Extent.SpatialReference.WKID == 102100 ||
    MyMap.Extent.SpatialReference.WKID == 102113 ||
    MyMap.Extent.SpatialReference.WKID == 3857)
    // we must be in web mercator, so lets convert our point appropriately...
    MapPoint mapPoint = ESRI.ArcGIS.Client.Bing.Transform.GeographicToWebMercator(new MapPoint(GeoPosition.Latitude, GeoPosition.Longitude));
else
...or is there another way of checking?  Or am I misunderstanding the whole issue?
Any suggestions appreciated!  Sorry for the lack of knowledge
Cheers,
James
P.S. I got the WKID numbers after a bit of searching - perhaps they're not correct, or an incomplete set?
DominiqueBroux
Esri Frequent Contributor
It's correct and complete 🙂
The SpatialReference Equals method encapsulates the test on the different WebMercator WKID.
i.e. if you have 2 WebMercator spatial references (even with different WKID) sr1.Equals(sr2) returns true.
So one option to avoid hardcoding the 3 possible WKID is :
     if (new SpatialReference(102100).Equals(MyMap.Extent.SpatialReference)) { ......
JH2
Hi Dominique - great - just what I was looking for!
