slider inside legenda
885
01-26-2011 06:14 AM
MarcoRosa
Hi , hi have this case:
a arcgisdynamicmapservicelayer whitin of them just 1 layer. I observed that if
LayerItemsMode = flat the slider of opacity doesn't more visible instead if LayerItemsMode is Tree is visible.
Is there a way to view the slider in both case ? or workaround about this ?
thank's very much
GP
the code is the following:
          <esri:Legend x:Name="legenda" Map="{Binding ElementName=Map}"
                         LayerItemsMode="Flat"
                         ShowOnlyVisibleLayers="False"
                         Refreshed="Legend_Refreshed">
                <esri:Legend.MapLayerTemplate>
                    <DataTemplate>
                          <StackPanel Orientation="Horizontal">
                            <Grid x:Name="BusyIndicator" Background="Transparent" Margin="3,0"
       HorizontalAlignment="Left" VerticalAlignment="Center" RenderTransformOrigin="0.5,0.5" >
                                <Grid.Triggers>
                                    <EventTrigger RoutedEvent="Grid.Loaded">
                                        <EventTrigger.Actions>
                                            <BeginStoryboard>
                                                <Storyboard>
                                                    <DoubleAnimation Duration="0:0:1" RepeatBehavior="Forever" To="360" Storyboard.TargetName="BusyIndicator"
                     Storyboard.TargetProperty="(UIElement.RenderTransform).(RotateTransform.Angle)" />
                                                </Storyboard>
                                            </BeginStoryboard>
                                        </EventTrigger.Actions>
                                    </EventTrigger>
                                </Grid.Triggers>
                                <Grid.RenderTransform>
                                    <RotateTransform />
                                </Grid.RenderTransform>
                                <Ellipse Fill="#1E525252" Margin="11,2,11,20" Width="2" Height="2"/>
                                <Ellipse Fill="#3F525252" Height="3" Width="3" VerticalAlignment="Top" HorizontalAlignment="Right" Margin="0,4,5,0" />
                                <Ellipse Fill="#7F525252" Width="4" HorizontalAlignment="Right" Height="4" VerticalAlignment="Top" Margin="0,9,1,0" />
                                <Ellipse Fill="#BF525252" Height="5" Width="5" VerticalAlignment="Bottom" Margin="0,0,3,3" HorizontalAlignment="Right" />
                                <Ellipse Fill="#FF525252" Height="6" Width="6" VerticalAlignment="Bottom" Margin="9,0" />
                            </Grid>
                            <CheckBox Content="{Binding Label}"
                  IsChecked="{Binding IsEnabled, Mode=TwoWay}"
                  IsEnabled="{Binding IsInScaleRange}">
                            </CheckBox>
                            <Slider Maximum="1" Value="{Binding Layer.Opacity, Mode=TwoWay}" Width="50" />
                          </StackPanel>
                    </DataTemplate>
                </esri:Legend.MapLayerTemplate>
                <esri:Legend.LayerTemplate>
                    <DataTemplate>
                        <CheckBox x:Name="CheckBoxLayers" Content="{Binding Label}"
                IsEnabled="{Binding IsInScaleRange}" Checked="CheckBox_Checked"
                            Unchecked="CheckBox_Unchecked">
                        </CheckBox>
                    </DataTemplate>
                </esri:Legend.LayerTemplate>
            </esri:Legend>
DominiqueBroux
Esri Frequent Contributor
You can add the same slider to the layerTemplate:
<DataTemplate>
</CheckBox>
</StackPanel>
</DataTemplate>
This is obsiously not modifying the opacity of the sublayer (that's not possible) but of the main service layer. But as you have only one sublayer in your service, the result is the same.
MarcoRosa
it's perfect thank u
byeee
