Silverlight platform 32-bit support only?
1218
10-19-2010 02:11 PM
AmrinderGanda
I was going through ArcGIS Resource Center for Silverlight API and found out that the Silverlight platform provides 32 bit support only. What exactly does this mean/impact? Like, is this a restriction from development perspective? Or does that restricts deployment in any form? Or something else?
AG
JenniferNery
You might have already visited the following sites:
http://arstechnica.com/microsoft/news/2010/01/why-microsoft-isnt-working-on-silverlight-64-bit.ars
http://blogs.msdn.com/b/ieinternals/archive/2009/05/29/q-a-64-bit-internet-explorer.aspx
The 64-bit version of Internet Explorer is not currently supported by Silverlight (neither do Flash) so users of your Silverlight app need to use 32-bit version.  There's some Q&A on the second link on what kind of things will not work on 64-bit IE.
AmrinderGanda
That helps. Thanks for the information Jennifer.
AG
dotMorten_esri
Esri Notable Contributor
I would put it this way: If your webapplication uses so much memory that you require to run it on 64bit, your app is doing something very wrong 🙂
AmrinderGanda
Thanks for the input Morten.
Hopefully, we wont run into memory problems, as usual 🙂
AG
