Silverlight  4 Tools Installation
1698
01-07-2014 10:45 AM
ShaningYu
Honored Contributor
For some reason, I have to run SL 4 projects.  However, I receive a ton of compiling errors.  Then I tried to re-install all of the SW needed for SL API project by referring to http://help.arcgis.com/en/webapi/silverlight/help/index.html#/Installation/016600000005000000/.
I repaired VS 2010 and VS 2010 SP1.  Then I tried to install Silverlight 4 Tools for Visual Studio but got failure.  The error message is:
Installation Requirements:
Visual Studio 2010 or Visual Web Developer Express 2010 or Visual Phone Developer Express 2010 that matches the language version of Silverlight Tools 4 must be installed before installation of Silverlight Tools can continue.  Silverlight Tools is available in other languages at <A HREF="http://go.microsoft.com/fwlink/?LinkId=177432">http://go.microsoft.com/fwlink/?LinkId=177432</A>.
Since I did have installed VS 2010, I don't know what measure I should take next.  I wish ESRI SL Team or some experienced professionals can provide some help.  Thanks.
By the way, got another Q here.  From the API:
Silverlight Version 4 is supported:
    Silverlight 4 Tools for Visual Studio (add-on required if using Visual Studio 2010 without SP1)
Since I installed SP1, is the SL 4 Tools still required?
ShaningYu
Honored Contributor
From http://stackoverflow.com/questions/5402774/cannot-install-silverlight-4-tools-on-visual-studio-2010-...,
"The VS 2010 Service Pack 1 has SilverLight Toolkit install as default. You don't need to install the SilverLight tool anymore."
ShaningYu
Honored Contributor
