Silverlight control blank when moved to production server
1044
10-12-2011 05:44 AM
EvanBossett
I have developed a .NET application using Visual Studio 2010 and the ESRI Silverlight "ArcGIS API for MS Silverlight-WPF 2.1".  It works fine on my local development machine in debug mode.  However, when i deploy the application and try to access the ASPX page w/ the silverlight XAP in it, it just loads as a blank white silverlight (if i right click, i get the "Silverlight" menu).  However, nothing else shows up.
Any tips?
Thank you
dotMorten_esri
Esri Notable Contributor
Did you add the mime type for .xap files to your webserver?
See the last entry in the faq:
http://help.arcgis.com/en/webapi/silverlight/help/index.html#/FAQs/016600000009000000/
EvanBossett
thank you very much
