server 500 error
3281
11-05-2010 10:40 AM
ScottTansley
This is probably a really pathetic question, but I'd appreciate some help!
I wrote a Silverlight APIv1.0 app against 9.3.1.  I've recently upgraded to 10.0, and so I thought I'd move everything over to APIv2.0.  My app works fine when debugging but when I publish the app to IIS I get all sorts of errors.  Initially, i was got a "Unrecognized attribute 'targetFramework'" - I quickly worked out that the Application Pooll the app was running against was .Net 2.0.  So I created a new "4.0 Intergrated" pool, and then pointed my web application at that.  I have checked "basic settings" on IIS7 (win 7 64-bit), and can confirm it's looking at the correct pool.  when I look at the pool, it tells me that 1 application is referencing it.
The problem now is that I've got a server 500 error.  Thinking my code was bad, I created a new Blank Silverlight app on it, dropped a map control on - pointed it at a dynamic layer, and it runs in debug - but exactly the same on iis.  I even created an ESRI Standard Silverlight Template app, and built/published it raw and I get the same problem.
The laptop was only built this week, is runnign ArcGIS Server 10 with no problems.
One thing I should point out, is that it is fine if it runs as a html page, but I need it to run as an aspx, as I have a web.config with some initial settings that it needs.
Any pointers would be most gratefully received.
Kind Regards,
Scott
DarinaTchountcheva
Hi Scott,
I have just deployed yesterday a .Net Framework 4 application on IIS 6.
I did all the steps you did (I had to install .Net Framework 4 too), and after all this I got 404 error.
I resolved this by allowing the ASP.Net 4 Web Extension (it was prohibited after the installation) on the web server.
I know your error is different, but check if ASP.Net 4 is allowed on your IIS7. And here is a little hint where to find the web extensions on IIS7 (I am still finding my ways around IIS 7):
http://blogs.msdn.com/b/rakkimk/archive/2007/08/17/iis7-where-is-the-web-services-extensions-option-...
Hope this resolves your problem.
Please post your solution if you figure it out, because I will have to deploy on IIS 7 too. 😉
Good Luck!
StevenMorlock
also make sure your application pool is running in 32bits mode if you are using (serverside) ArcObjects.
ScottTansley
Heh Darina,
Thanks for your help.  Much appreciated.
As you suggested, I read the instructions that you sent through, and registered the web extensions.  Still no joy, then noticed what you said about installing .Net 4!  As I mentioned in my first post, my laptop has been rebuilt this week. The guy from tech services had installed Visual Studio 2010 before installing IIS.  It would appear that .Net 4 therefore does not get properly registered with IIS, even though you can set up the Application Pools.
I found that there is a aspnet_regiis tool, which allows you to install .Net 4 onto IIS.  Read here:
http://msdn.microsoft.com/en-us/library/k6h9cz8h.aspx
Undertook this for both 32 and 64 bit frameworks, retested my app - and heh presto.
So, many thanks for pointing me in the right direction!  🙂
Hope you have a great weekend.
Scott
