Selection Of Multiple Graphics In Layer
1634
5
05-18-2010 02:27 PM
HeavyWoody
I am creating a graphics layer at runtime from code behind.  What I really would like to do is allow the user to use like the Query piece where you can draw a bounding box (or rubberband), and then be able to loop through the graphics layer and check to see which graphic items fell into the area that was drawn.  I see demos on Feature Services doing this, but like I said, I building a graphics layer at runtime so I cannot do it like that.
Is this possible?  If so, how?
dotMorten_esri
Esri Notable Contributor
The Editing class in v2.0 fully supports selection on GraphicsLayer, as long as the selectionmode is point or rectangle. Only if you need to select by polyline or polygon does it have to be a FeatureLayer.
Links:
http://help.arcgis.com/en/webapi/silverlight/apiref/topic238.html
http://help.arcgis.com/en/webapi/silverlight/apiref/topic214.html
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsExplicitSave
You could also go more low-level and use the FindGraphicsInHostCoordinates method which is also supported in v1.2:
http://help.arcgis.com/en/webapi/silverlight/apiref/topic487.html
AlexAgranov
I made this work in WPF, however at the cost of the ability to navigate the map in NWSE by dragging it. I intercept the Map-->MouseDown event to activate the Editor.Select command but it prevents navigation. In order to keep default navigation in place, I'd have to move activate the select command from another button or toolbar.
JenniferNery
The Editor supports GraphicsLayer too, you can look at this sample for guide:http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#EditToolsAutoSave. Look at the "Select" buttons.
The only thing you will need to do is when you create your GraphicsLayer, give it an ID. The Editor ignores layers that do not have IDs. Also you can set Editor's Map property but leave its LayerIDs alone, you don't need to specify this if your layers will be added at runtime and you do not have this information yet. Setting the Map property is sufficient.
AlexAgranov
What if I don't want to use Editor for multiple selection. Let's say I subscribe to Graphic.MouseLeftButtonUp event and call Graphic.Select(). For some reason the graphics layer will only remember the last selection. How do I enable multiple select on a graphics layer so it doesn't do that?
dotMorten_esri
The Editor actually does what you are doing (although it used the Draw object, and it's the draw object that prevents navigation), so it is possible to do with intercepting events. I'm not sure how you would NOT disable map navigation while drawing on the map. Doing both at same time would be really confusing. Either you draw on the map, or you navigate the map.
