select points inside multiple polygons
2020
04-25-2013 03:08 AM
MohamedAl_Jishi
Hi
I have two layers in my map. The first layer is points, and the second layer is polygons
I want to select points that is inside the selected polygons based on attributes
I can use querytask on polygon using attribute and return the polygon graphics, and then using this graphics with querytask on points using spatial query to return the point inside this polygon. This method works great if I have only one polygon and I want to select the points inside this single polygon, but I cannot use it if I have more than one polygon !!!!
This my code I used it select points.
 Private Sub Button1_Click(sender As System.Object, e As System.Windows.RoutedEventArgs) Handles Button1.Click
        Dim QueryTask As New QueryTask(PolygonURL)
        AddHandler QueryTask.ExecuteCompleted, AddressOf QueryTask_ExecuteCompleted
        AddHandler QueryTask.Failed, AddressOf QueryTask_Failed
        Dim query As New ESRI.ArcGIS.Client.Tasks.Query
        query.Where = "ZONE_TYPE='URBAN AREA'"
        query.OutSpatialReference = MainMap.SpatialReference
        query.OutFields.Add("*")
        query.ReturnGeometry = True
        QueryTask.ExecuteAsync(query, "GetZoneGeometry")
    End Sub
    Private Sub QueryTask_ExecuteCompleted(sender As Object, e As QueryEventArgs)
        If TryCast(e.UserState, String) = "GetZoneGeometry" Then
            Dim QueryTask As New QueryTask(PointURL)
            query.Where = "1=1"
            query.Geometry = e.FeatureSet.Features(0).Geometry ' How to use all geometries ???????
            QueryTask.ExecuteAsync(query, "SelectPoint")
        ElseIf TryCast(e.UserState, String) = "SelectPoint" Then
            If e.FeatureSet.Features IsNot Nothing AndAlso e.FeatureSet.Features.Count > 0 Then
                '  add points to graphics layer
            Else
                MessageBox.Show("No result found")
            End If
        End If
    End Sub
In this code I want to select all points inside Urban Areas.
