Save layer to kml
1511
5
06-21-2010 07:42 PM
LedonneJuan
Hi, it is possible to save a dynamic or tiled map layer to kml? if yes, can anyone post a sample code.
and also how can i dynamically add a kml file?
thanks and God Bless
DominiqueBroux
Esri Frequent Contributor
To create KML files, you can use the GP tools : MapToKML and/or LayerToKml.
To create a kml layer in a ESRI silverlight application, there is a sample here : http://resources.esri.com/arcgisserver/apis/silverlight/index.cfm?fa=codeGalleryDetails&scriptID=164...
and a thread here : http://forums.arcgis.com/threads/4897-KML-layer
LedonneJuan
Thanks for the reply. is it possible to add kml layer from local hard disk, just like in arc explorer
DominiqueBroux
The sample is not designed to allow adding kml layer from local hard disk.
But I guess, it's possible to modify it in order to get a file by 'OpenFileDialog' and to use this file to populate the kml layer.
DanielWalton
This is very easily done. Search through the KML sample code and you will eventually find the code that converts a stream object into an XDocument object. You just have to write code to connect an OpenFileDialog.File.OpenRead() (Filestream) object to that routine.
LedonneJuan
thanks for the replies. i will try your advices.
God Bless
