routing task error on android
3000
05-28-2016 09:27 PM
tohamihussin1
i can not perform routing
whin i run this code it does not give any errors , i have make logs every where to figure out what is the problem and i found that its stop at  parameters = task.retrieveDefaultRouteTaskParameters(); , or any where i use routing task "task"
pleeeeeeese help me
RouteParameters parameters = null;
RouteTask task = null;
try {
  task = RouteTask.createOnlineRouteTask(
   "http://sampleserver6.arcgisonline.com/arcgis/rest/services/NetworkAnalysis/SanDiego/NAServer/Route", null);
  Log.e("result" ,"142");
  parameters.setOutSpatialReference(mMap.getSpatialReference());
  NAFeaturesAsFeature naFeatures = new NAFeaturesAsFeature();
  Log.e("result" ,"1");
  Point startPoint = new Point(-119.866896, 36.793653);
  Point stopPoint = new Point(-119.853345, 36.795488);
  StopGraphic startPnt = new StopGraphic(startPoint);
  StopGraphic stopPnt = new StopGraphic(stopPoint);
  Log.e("result" ,"2");
  naFeatures.setFeatures(new Graphic[] {startPnt, stopPnt});
  naFeatures.setSpatialReference(mMap.getSpatialReference());
  parameters.setStops(naFeatures);
  RouteResult result = null;
  result = task.solve(parameters);
  Log.e("result" , result.getStops().toString()) ;
} catch (Exception e) {
  e.printStackTrace();
