Routing error in ArcGIS Server 10
1331
01-17-2011 06:10 PM
JollyJacob
We had the routing functionality working well in our Web Viewer (9.3.1) but the same does not work after we moved to 10. 'Routing error - unable to complete operation'. The network dataset was rebuilt in 10 and solving routes is working fine in the mxd. The only thing we haven't done so far is upgrade the db to 10. Any help would be much appreciated.
Regards
Jolly
JenniferNery
I'm not sure I understand the question. Are you using our API and current code does not work after upgrading to ArcGIS Server 10? Which version of the Silverlight/WPF API are you using? It's hard to tell whether the issue is with upgrading the server. Maybe you can try to use Fiddler or make the request outside the API through the web browser. Kindly look at post #14 in this thread http://forums.arcgis.com/threads/14730-Area-And-Perimeter
JollyJacob
Thanks for replying Jennifer. Yes, we are using ArcGIS SL API 2.1. Fiddler is something we haven't tried yet. I guess it would be worthwhile trying it out.
