Result of selection in a datagrid
888
03-01-2011 05:28 AM
MarcoRosa
Hi ,
i would like to put into a datagrid the result of selecion on a feature layer ( throught editor tool).
It's possibe to do that ?
Now I'm using for that a FeatureDatagrid. I would like to know if this is possible with datagrid too.
Thanks 1000
GP
JenniferNery
Sure, this is possible. You can subscribe to the Editor's EditCompleted event and check for Editor.EditEventArgs.Action (http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Editor+Edi...) and Editor.EditEventArgs.Edits (http://help.arcgis.com/en/webapi/silverlight/apiref/ESRI.ArcGIS.Client~ESRI.ArcGIS.Client.Editor+Cha...). You should be able to get SelectedGraphics from the layer (edit.Layer or edit.Graphic). If your data grid contains GraphicCollection, you should be able to do something like: dataGrid.SelectedItem = edit.Graphic
dotMorten_esri
Esri Notable Contributor
