Remove Unwanted Vertices
4390
07-26-2010 05:39 AM
LakshmananVenkatesan
Hello All
I want to remove unwanted (Overlapping or vertices on same line) vertices from the graphics polygon using SliverLight API. Can any one provide me best method to do it?. Attached is polygon. I want to remove the vertices B,C, F, G
I need to do this same for irregular polygon as well.
Regards
SR
DominiqueBroux
Esri Frequent Contributor
With 10, the geometry service has a new utility method called 'Generalize'.
It shoud do the job you are expecting.
See sample here : http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#Generalize
