Refresh Dynamic Layer using timer
3713
05-25-2010 04:59 AM
PieterCoetzer
Hi Guys,
I'm trying to refresh a map view loaded in a WPF application, based on a timer.
I have tried to refresh the Dynamic Layers using the Layer.Refresh() on the timer's interval, but it does not refresh the map view. Only when a pan or zoom event is done on the map viewer, then the view refreshes.
My code:
Window Load:
DispatcherTimer localTimer = new DispatcherTimer();
localTimer.Tick += new EventHandler(localTimer_Tick);
localTimer.Interval = new TimeSpan(0, 0, 30);
Method to refresh the layers:
private void localTimer_Tick(object sender, EventArgs e)
     foreach (Layer layer in MyMap.Layers)
     if ((layer is DynamicLayer) && (layer.Visible == true))
         (layer as DynamicLayer).Refresh();
Any suggestions??
dotMorten_esri
Esri Notable Contributor
Did you set DisableClientCache=False on the layer?
PieterCoetzer
Hi Morten,
I actually left it default, but with you highlighting this, I changed the property to true and whala, it refreshes.
Thanks for the guidance.
In the layer load method:
NewDynLayer.DisableClientCaching = true;
dotMorten_esri
Default settings are usually set for maximum performance. This means that for certain scenarios (like this) you might have to tweak the defaults.
BrandonLand
This was VERY helpful to me guys, thank you.
