Query Attributes Tool No longer works with SL 2.0 and ArcGIS 10.0 REST
2475
08-23-2010 08:41 AM
BrockTerry
I've noticed that the "Query Attributes" tool is throwing an error when I tie the tool to a ArcGIS 10 REST service.  If I point the code at a 9.3.1 REST service it works fine.
The project will build with no errors but when I use the tool and select an attribute it stops at this line of code in the .cs page:
// Zoom to selected feature (define expand percentage)
                ESRI.ArcGIS.Client.Geometry.Envelope selectedFeatureExtent = selectedFeature.Geometry.Extent;
BrockTerry
This is the error that I get:
System.NullReferenceException was unhandled by user code
  Message=Object reference not set to an instance of an object.
  StackTrace:
       at Standard.MainPage.QueryTask_ExecuteCompleted(Object sender, QueryEventArgs args)
       at ESRI.ArcGIS.Client.Tasks.QueryTask.OnExecuteCompleted(QueryEventArgs args)
       at ESRI.ArcGIS.Client.Tasks.QueryTask.request_Completed(Object sender, RequestEventArgs e)
       at ESRI.ArcGIS.Client.Tasks.TaskBase.request_Completed(Object sender, RequestEventArgs e)
       at ESRI.ArcGIS.Client.WebRequest.OnComplete(RequestEventArgs args)
       at ESRI.ArcGIS.Client.WebRequest.downloadStringCompleted(Object sender, DownloadStringCompletedEventArgs e)
       at System.Net.WebClient.OnDownloadStringCompleted(DownloadStringCompletedEventArgs e)
       at System.Net.WebClient.DownloadStringOperationCompleted(Object arg)
  InnerException:
BrianGustafson
Try explicitly setting the return geometry = true in your query parameters.  Is your selected features geometry attribute null?
BrockTerry
That did the trick!
Thanks so much.
