Pulish feature in arcgis server as server with code?(using silverlight arcgis server 10.2)
3223
10-08-2014 01:21 PM
MostafaKhoshabi
I want to build a WebGIS that within users be able upload our shape file and this shape file save in arcgis server 10.2 as server and i can use this rest service. How can it? in my webGIS i use ArcgisServer 10.2 , ArcGIS API for silverlight 3.2 , SQLServer 2008 R2.
DominiqueBroux
Esri Frequent Contributor
ArcGIS API for Silverlight doesn't support publishing a feature service.
You have to publish the service from Portal, Server or Desktop.
These links may help:
Alternatively, if you want to automate the process, you might create a geoprocessing service that would create the feature service from a shapefile.
DominiqueBroux
MostafaKhoshabi
Hi Dear Dominique
thanks for your attention. Do you have sample code or sample geoprocessor for this work?
best regards
