Projection Question
1035
09-08-2010 07:46 AM
PaulHuppé
I am using the Selection Tool and for some layers, the selected polygons appear way off the map. During debugging, I noticed that the features selected come from a layer which has a different WKID than the map. That is the features.Geometry.SpatialRefenrence is not equal to the Map.SpatialRefenrence.
My question is how do I project the features from their SpatialRefenrence to the map's SpatialReference so that they show up in the correct location on the graphics layer?
Paul
AliMirzabeigi
What if you set the map SpatialReference to what is defined in your GraphicsLayer? You can do so by setting the SpatialReference in your map's initial extent; please see the following sample to get the whole idea:
http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#DefineMapProjection
dotMorten_esri
Esri Notable Contributor
If you are using the QueryTask, did you set the OutputSpatialReference property to match that of the map?
PaulHuppé
I was using the QueryTask, so setting the QueryTask's spatial reference to be equal to the Map's spatial reference worked.
Paul
