Problem with dynamic binding to featuredatagrid
727
05-28-2010 12:03 PM
JamesMolohon
Hi all,
I'm having trouble with a featuredatagrid that I want to programmatically switch the graphicslayer that it is bound to.  When I set the graphicslayer in code like the snip below, the grid appears empty, without gridlines or anything.
MyDataGrid.GraphicsLayer = MyMap.Layers("XYZ")
I have been able to get the grid to work with all of my map layers individually, but not able to switch the grid to utilize a different source.  What am I missing?
Regards,
James M.
DominiqueBroux
Esri Frequent Contributor
Might be the same issue than this one : http://forums.arcgis.com/threads/2896-FeatureDataGrid-and-SL-API-v2.0?highlight=featuredatagrid
Which version of the ArcGIS SL API are you using?
JamesMolohon
Thanks, I'm on the 1.2 SDK.  I think that I will need to update to Silverlight 4 and the v2.0 SDK.
