PritingTools - US Standard Paper -  8 1/2 * 11
802
09-12-2013 06:13 AM
JoshuaBirappagari1
I am looking under samples for silver light.
1. http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ExportWebMap
2. http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ClientPrinting
I don't see an option for US Standard Paper - 8 1/2 X 11.  How do I add it to the list of layouts.
Thanks.
Noah-Sager
They should all work with US Standard Paper - 8 1/2 X 11.
1) http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ExportWebMap
Exports an image that you can save on your computer. You can experiment with what you want them to look like.
2) http://resources.arcgis.com/en/help/silverlight-api/samples/start.htm#ClientPrinting
Previews what the image will look like after you print it. This still requires you to set-up your hardware printer settings. If you want to print on 8 1/2 X 11, then you can do so, in either portrait or landscape mode.
Hope this helps
-Noah
