PrintTask with a proxy
1166
10-01-2012 02:27 PM
DorothyMortenson
Hello,
I have a web application that has one dataset that is secured through a proxy service. It is only available inhouse.
<esri:ArcGISDynamicMapServiceLayer ID="Tax Lots"
                         Url="http://someurl/ArcGIS/rest/services/Secure/taxlots/MapServer"
                         ProxyURL="../../../SilverlightProxy/proxy.ashx" VisibleLayers="0"
                         Opacity="1.0" />
I am using the new printtask to allow for printing.  It does not work tho because of this dynamicmapservicelayer.
Do I need to add some kind of proxy for the printtask?
Suggestions on how to do this?
Dorothy
DominiqueBroux
Esri Frequent Contributor
Your issue might be with the proxy relative path.
From the print server, this relative path is likely wrong.
Try by setting an absolute path (by code if needed)
DorothyMortenson
I tried the URL to the proxy and it still does not print.
DorothyMortenson
I solved it, almost...
In the ExportMap_Click, I turn off the secured layer before I print. This does not help, tho, should we want to actually print the features on the secured layer.
if (myLayer.ID == "Tax Lots" )
        myLayer.Visible = false;
But your suggestion of using the full url for the proxy helped with another issue I had - I wasn't able to test the application right from Visual Studio with the relative pathname.  With the full pathname, I can. Yeah! 😄
For the full code of the ExportMap_Click...
private void ExportMap_Click(object sender, RoutedEventArgs e)
            if (printTask == null || printTask.IsBusy) return;
            busyIndicator.Visibility = Visibility.Visible;
            // Define the LegendOptions. This will show specified Layers in the printed map's legend area.
            LegendOptions myLegendOptions = new LegendOptions();
            // Define a List<LegendLayer> objects to put in the LegendOptions.
            List<LegendLayer> myLegendLayers = new List<LegendLayer>();
            // Loop through all of the Layers in the Map Control.
            foreach (var myLayer in MyMap.Layers)
                // Create a new LegendLayer object to put in the List<LegendLayer> collection.
                LegendLayer myLegendLayer = new LegendLayer();
                // Set the LegendLayer.LayerId to the Layer.ID to add it to the printed map's legend area.
                myLegendLayer.LayerId = myLayer.ID;
                if (myLayer.ID == "Water Rights" || myLayer.ID == "OWRD Layers")
                    // Add a single LegendLayer into the List<LegendLayer> collection.
                    myLegendLayers.Add(myLegendLayer);
            // Set the LegendOptions.LegendLayer to the new constructed List<LegendLayer> objects.
            myLegendOptions.LegendLayers = myLegendLayers;
            PrintParameters printParameters = new PrintParameters(MyMap)
                LayoutOptions = new LayoutOptions() { Title=MapTitle.Text,
                    LegendOptions = myLegendOptions},
                ExportOptions = new ExportOptions() { Dpi = 96, OutputSize = new Size(MyMap.ActualWidth, MyMap.ActualHeight) },
                LayoutTemplate = (string)LayoutTemplates.SelectedItem ?? string.Empty,
                Format = (string)Formats.SelectedItem,
            printTask.ExecuteAsync(printParameters);
