Printing with PictureFillSymbol
760
01-14-2013 06:19 AM
YamunadeviRathinasamy
I am using PictureFillSymbol to display a photo on Map.
The Envelope is created based on the Map scale. And which works fine in the UI for zoom in and out.
If I print it won't work. then I converted Envelope to polygon and tried printing which works. howevere it is not scalling the image.
BitmapImage Bmp = sender as BitmapImage;
            if (Bmp != null)
                //use is pixel dimensions to calculate scale
                double ImgWidth = Bmp.PixelWidth;
                double ImgHeight = Bmp.PixelHeight;
                if (Map.Extent.Width > 0 && Map.Extent.Height > 0) //stop div by zero
                    //calculate a scale to make the image 1/10th of map (at current zoom level)
                    double scale = ImgWidth / (Map.Extent.Width * 0.1);
                    scale = Math.Max(scale, ImgHeight / (Map.Extent.Height * 0.1));
                    if (scale > 0)//stop div by zero
                        MapPoint photoMapPointA = InsertionPoint;
                        MapPoint photoMapPointB = new MapPoint((photoMapPointA.X + ImgWidth / scale), (photoMapPointA.Y - ImgHeight / scale));
                        Envelope photoEnvelope = new Envelope(photoMapPointA, photoMapPointB);
                        ESRI.ArcGIS.Client.Geometry.Polygon p=new ESRI.ArcGIS.Client.Geometry.Polygon();
                        ESRI.ArcGIS.Client.Geometry.PointCollection pc = new ESRI.ArcGIS.Client.Geometry.PointCollection();
                        pc.Add(new MapPoint(photoEnvelope.XMin, photoEnvelope.YMin));
                        pc.Add(new MapPoint(photoEnvelope.XMin, photoEnvelope.YMax));
                        pc.Add(new MapPoint(photoEnvelope.XMax, photoEnvelope.YMax));
                        pc.Add(new MapPoint(photoEnvelope.XMax, photoEnvelope.YMin));
                        p.Rings = new ObservableCollection<ESRI.ArcGIS.Client.Geometry.PointCollection>();
                        p.Rings.Add(pc);
                        Graphic g = new Graphic();
                        g.Geometry = p;// photoEnvelope;
                        PictureFillSymbol pfs = new PictureFillSymbol();
                        pfs.Source = Bmp;
                        g.Symbol = pfs;
                        (Map.Layers[3] as GraphicsLayer).Graphics.Add(g);
