Print Example Issues
1285
07-15-2011 09:11 AM
CyndieEnfinger
I'm attempting to use the Print tool from this example and am having multiple issues:
http://www.arcgis.com/home/item.html?id=e361c2cc69784fcba34358d0458f66e3
1. Even though I've set the MapUnits to Feet, it prints NaN Kilometers on the map.  Does anyone know how to fix this?
2. If I print this to one printer (color), I get a blank page or just the background gradient, but if I print the same exact map to a different printer (which is black and white), I get a map on the page. The printed page, however, has a gradient background which makes the map hard to see.  How can I turn the gradient off as I suspect it is making the size of the image too large for some printers?
3. Sometimes when I click the print button, the print busy indicator comes up as expected, but when it finishes, the page does not print.  Has anyone else seen this?
Thanks for any help!
DeminHu
I used the sample long time ago,  I went inside  the control source code, made a little change, it  really worked for me.
CyndieEnfinger
I'm glad it is working for others.  Hopefully, if I can get these issues resolved, I'll feel the same way.  So far, looking in the code has not helped.  I've commented out gradients that I see, but I still get that purple gradient background.
