Print Bing Map in ArcGIS API Silverlight
1398
5
09-26-2010 04:23 PM
JoseSousa
Dear ArcGIS API for Flex Team,
Is it possible to print a Bing Map contained inside the ArcGIS Silverlight Map Control?
If not is there a workaround to do it?
Cheers,
Victor
dotMorten_esri
Esri Notable Contributor
"Dear Flex team"? You might want to try in the Flex forum 🙂
JoseSousa
🙂 Old habit,
I meant ArcGIS API for Silverlight Team.
Is there any chance of doing this using the ArcGIS API for Silverlight?
Is this something that is not supported with Silverlight? Is there a workaround?
Cheers,
Victor
dotMorten_esri
I don't see why Bing would be any different from any of the other layers. You can still use the PrintDocument API's to print stuff out.
JoseSousa
I was trying to do it server side. There will be some limitations doing this client side but I think it will work.
Thanks a lot,
Victor
dotMorten_esri
Since these tiles are coming from a different domain, reading the pixels will be blocked because of security restrictions.
If you run your app in full-trust mode, it will work, however that would require the user to run the app in out of browser mode.
