New Silverlight Toolkit
2786
06-22-2010 05:16 PM
TedCronin
Will there be a new Silverlight Toolkit for the version 2.0 API RC?  Basically, where do I find this content Additional data sources are supported in a new library packaged with the ESRI Silverlight Toolkit.  Data sources include GeoRSS, OpenStreetMap, WMS, and client generated heat maps. Note, source code for the toolkit will be available when 2.0 final is released in early July 2010.   Is this part of the March 2010 - v1.2?
dotMorten_esri
Esri Notable Contributor
The toolkit is included in the v2.0 RC. If you install it, you will get the extra DLL.
As you yourself mention, we will release the sourcecode when v2.0 goes final. As usual this will be available on http://esrisilverlight.codeplex.com
Since this is v2.0, it is not part of v1.2
TedCronin
Thank you.
PeterChifamba
I have looked at the API v.20 RC and there is no extra dll for datasources
mattdarnall
I found the assembly in the install location, for me:
C:\Program Files (x86)\ESRI SDKs\Silverlight\v2.0
ESRI.ArcGIS.Client.Toolkit.DataSources.dll
PLadd
I couldn't find the dll either.  So I uninstalled v. 2.0, downloaded it again from ESRI
(http://help.arcgis.com/en/webapi/silverlight/index.html) and reinstalled.
This did the trick.
