MyMap_MouseOver issue..
1686
7
08-04-2010 04:03 AM
JoshV
When my Silverlight App is loading in the browser, if I have my mouse hovering over the map area I will get a "Object reference not set to an instance of an object".  The error states this occured in MyMap_MouseOver event.  The App will load fine as long as the mouse cursor is not on the map when the App is loading but I can't take the chance a user will do that.  Does someone have some suggestions?
many thanks.
jonataspovoas
I made a Small Application to demonstrate a possible solution to your problem.
the Xaml has a Map and a Border with a TextBox that Show the mouse position on the screen or OOB (out of border) if the mouse is out of the map. here's the code:
XAML:
<UserControl x:Class="MouseOverTest.MainPage"
    xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
    xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
    xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
    xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
    xmlns:esri="http://schemas.esri.com/arcgis/client/2009"
    mc:Ignorable="d" d:DesignWidth="780" d:DesignHeight="480"
 xmlns:i="clr-namespace:System.Windows.Interactivity;assembly=System.Windows.Interactivity"
    xmlns:ei="clr-namespace:Microsoft.Expression.Interactivity.Core;assembly=Microsoft.Expression.Interactions"
    xmlns:userControls="clr-namespace:ESRI.ArcGIS.SilverlightMapApp"
    xmlns:actions="clr-namespace:ESRI.ArcGIS.SilverlightMapApp.Actions">
    <Grid x:Name="LayoutRoot">
        <!-- Map Control -->
        <esri:Map x:Name="MyMap" Background="White">
            <esri:ArcGISTiledMapServiceLayer ID="BaseLayer"
          Url="http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer" />
        </esri:Map>
        <Border BorderThickness="2" BorderBrush="Black" Height="50" Width="100" Margin="12,418,668,12">
            <TextBlock Name="mousePosition"/>
        </Border>
    </Grid>
</UserControl>
CS:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Net;
using System.Windows;
using System.Windows.Browser;
using System.Windows.Controls;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Animation;
using System.Windows.Markup;
using System.Windows.Shapes;
using System.ComponentModel;
using ESRI.ArcGIS.Client;
using System.Windows.Controls.Primitives;
namespace MouseOverTest
    public partial class MainPage : UserControl
        public MainPage()
            InitializeComponent();
            MyMap.Loaded += new RoutedEventHandler(MyMap_Loaded);
        private void MyMap_Loaded(object sender, RoutedEventArgs e)
            //choose what's best for your case
            MyMap.MouseEnter += new MouseEventHandler(MyMap_MouseEnter);
            MyMap.MouseMove += new MouseEventHandler(MyMap_MouseMove);
            MyMap.MouseLeave += new MouseEventHandler(MyMap_MouseLeave);
        private void MyMap_MouseEnter(object sender, MouseEventArgs e)
            mousePosition.Text = string.Format("OOB");
        private void MyMap_MouseMove(object sender, MouseEventArgs e)
            mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(LayoutRoot).X.ToString(), e.GetPosition(LayoutRoot).Y);
        private void MyMap_MouseLeave(object sender, MouseEventArgs e)
I Hope this is useful XD
JoshV
XAML:
        </esri:Map>
        </Border>
    </Grid>
</UserControl>
CS:
using System;
using System.Linq;
using System.Net;
        public MainPage()
Hi I have a question on your code.  at  mousePosition.Text I'm getting "mouseposition" does not exist.  Can you offer me some advice on that?
Thanks
JoshV
Thanks
Ok I see that I left that out of my XAML.  So when user loads the web application and they hover over the map before the page loads your code will let the page load without an error occuring??
Regards,
jonataspovoas
well, I'm still new to silverlight, but in theory this code prevents the error, because the call that overrides the event MouseEnter, MouseMove and MouseLeave is only triggered after the map finishes loading, and, as I understood from your first post, the error ocurred because the map still didn't have an object instance.
JoshV
Hi jonatas-
That did work, thanks.  In your MyMap_MouseMove, it doesn't seem to return the actual XY's from the Map.  I'm guessing they are just the page XY's??  do you know how I can fix that?
-Thanks
jonataspovoas
That actualy isn't hard.
see this:
            //If you change LayoutRoot to any object that appears on the screen, the spacial
            //reference to the coordinates change, so, if you want the map coordinates,
            //you can change it to MyMap
            mousePosition.Text = string.Format("X: {0}, Y:{1}", e.GetPosition(MyMap).X.ToString(), e.GetPosition(MyMap).Y);
This should fix it!
Just to be sure, if your map is inside an ScrollViwer or a ChildWindow, this code Won't work well (i tried once, and i'm still trying to fix code for the childwindow)
JoshV
see this:
This should fix it!
Ok, thanks
