Multi-Ring Buffer
1295
07-16-2011 01:05 PM
karenvolarich
Where in this code would I place a "foreach" to get the multiple rings for buffer distances to show?  I tried on buffer execute completed - but than the query async fails.  Any insight would be appreciated.
      private void EditorEditCompleted(object sender, Editor.EditEventArgs e)
            if (e.Action == Editor.EditAction.Select)
                _geometryService.CancelAsync();
                _queryTask.CancelAsync();
                foreach (Editor.Change item in e.Edits)
                    Graphic clickGraphic = item.Graphic; //selected graphic
                    Layer layer = item.Layer;
                        clickGraphic.Symbol = LayoutRoot.Resources["YellowMarkerSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                        clickGraphic.Geometry = item.Graphic.Geometry;
                        _selectAndBufferGraphicsLayer.ClearGraphics();
                        clickGraphic.SetZIndex(2);
                        // If buffer spatial reference is GCS and unit is linear, geometry service will do geodesic buffering
                        ESRI.ArcGIS.Client.Tasks.BufferParameters bufferParams = new ESRI.ArcGIS.Client.Tasks.
                            BufferParameters()
        BufferSpatialReference =
        new SpatialReference(4326),
        OutSpatialReference =
        Map.SpatialReference,
        Unit = LinearUnit.StatuteMile,
                        bufferParams.Distances.AddRange(new double[] {10, 20, 50});
                        bufferParams.Features.Add(clickGraphic);
                        _geometryService.BufferAsync(bufferParams);
        void GeometryServiceBufferCompleted(object sender, GraphicsEventArgs args)
                Graphic bufferGraphic = new Graphic();
                bufferGraphic.Geometry = args.Results[0].Geometry;
                bufferGraphic.Symbol = LayoutRoot.Resources["BufferSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                bufferGraphic.SetZIndex(1);
                _selectAndBufferGraphicsLayer.Graphics.Add(bufferGraphic);
                ESRI.ArcGIS.Client.Tasks.Query query = new ESRI.ArcGIS.Client.Tasks.Query();
                query.ReturnGeometry = true;
                query.OutSpatialReference = Map.SpatialReference;
                query.Geometry = bufferGraphic.Geometry;
                query.OutFields.Add("*");
                _queryTask.ExecuteAsync(query);
        private void QueryTaskExecuteCompleted(object sender, QueryEventArgs args)
            if (args.FeatureSet.Features.Count < 1)
                MessageBox.Show("No features found");
                return;
            foreach (Graphic selectedGraphic in args.FeatureSet.Features)
                selectedGraphic.Symbol = LayoutRoot.Resources["OfficeSymbol"] as ESRI.ArcGIS.Client.Symbols.Symbol;
                //_resultsGraphicsLayer.Graphics.Add(selectedGraphic);
        private void GeometryServiceFailed(object sender, TaskFailedEventArgs args)
            MessageBox.Show("Geometry service failed: " + args.Error);
        private void QueryTaskFailed(object sender, TaskFailedEventArgs args)
            MessageBox.Show("Query failed: " + args.Error);
DominiqueBroux
Esri Frequent Contributor
You can't use an unique _geometryService to execute multiple requests in a loop.
Depending on your need, you can either create a new geoemtry service object in the loop, or (probably better) use an unique geometry object with a list of features (i.e you have to call 'Features.Add' in the loop but 'BufferAsync' outside of the loop.
