mouse offset on map
845
06-03-2010 11:13 AM
CraigPerreault
In 2.0 beta I have a Silverlight UserControl that has an ESRI.ArcGIS.Client.Map.  When I hold the shift key down to create a rectangle to zoom, the rectangle is not where I clicked.  Also, when I use the _MouseClick event the MapPoint is offset the same amount.
The code worked in 1.2
dotMorten_esri
Esri Notable Contributor
What does the layout tree around the map look like? Could you share a simplified example?
CraigPerreault
I have a small sample attached.
Click the Open  button on top then on the map in the pop up
Hold Shift and Drag a Rectangle (Notice the Offset)
