Merge or Union Graphics?
775
04-16-2010 11:33 AM
KadeSmith
I have two parcel graphics that I want to merge or union in to one graphic feature.  Is there anyway to do this or do I have to wait for AGS10 geometry service?
dotMorten_esri
Esri Notable Contributor
ArcGIS 10 Geometry service is your answer, unless you want to try and write your own union code 🙂
If you know the parcels doesn't overlap, you can simply just lump the rings collections together:
foreach(PointCollection points in polygon2.Rings)
     polygon1.Rings.Add(points);
