MapTips via Code-Behind
3704
09-01-2010 01:38 AM
AlexanderBlock
Hello,
is there any possibility to add MapTips to a GraphicsLayer via Code-Behind?
Code like the following ends with an ArgumentException when I hover over a MarkerSymbol;
var mapTip = (FrameworkElement)ESRIMap.Resources["ESRIMapTip"];
ObjectsGraphicsLayer.MapTip = mapTip;
For test purposes I use no binding in the MapTip XAML. It's just a plain border.
Any idea?
Regards,
Benjamin
DominiqueBroux
Esri Frequent Contributor
MapTip can't be defined as resource (even in XAML).
But you can define it by code the same way than in XAML : ObjectsGraphicsLayer.MapTip = new Border() { ......
dotMorten_esri
Esri Notable Contributor
I would create a custom usercontrol that contains everything you want in the maptip (including borders etc).
Then programmatically you simply set:
MyGraphicsLayer.MapTip = new MyMapTipUserControl();
You can still do all the binding stuff in this user control as you normally would when defining it straight in the Xaml.
PaulHuppé
I would also like to define map tips from code-behind.  I need to setup map tips for several layers each with a different list of fields to display. As Morton says, maybe a custom user control would do to define the look, but how do I pass it the fields I want to show?
Paul
dotMorten_esri
In you custom control you can generate the fields based on the Keys.
if add a Dependency Property to the UserControl and do the binding to that ie <local:MyMapTipControl Data="{Binding} />. In the DependencyPropertyChanged event handler, in the grid you have that contains the fields clear its children and its row definitions , and do a simple foreach on the keys/values to generate some new matching textblocks:
ie
int i=0;
foreach(var key in Data.Keys)
    ContainerGrid.Rows.Add(new RowDefinition());
    TextBlock tb = new TextBlock() { Text = key };
    tb.SetValue(Grid.Column, i++);
    ContainerGrid.Children.Add(tb);
    TextBlock tb2 = new TextBlock() { Text = value };
    tb.SetValue(Grid.Column, i);
    tb.SetValue(Grid.Row, 1);
    ContainerGrid.Children.Add(tb2);
