Map.ZoomToResolution fails to change map
2611
10
10-22-2010 01:36 PM
BryanBaker
Map.ZoomToResolution is working the first time I call it, but on subsequent calls, the map does not change its extent at all. I suspect this has something to do with the fact that my map service's spatial reference uses WKT (well-known text) rather than a WKID. I have worked around this by creating my own method, where I calculate the zoom envelope manually based on the map size and desired resolution. Using that method works consistently.
greatneal
Thanks bb1769, your codes are very useful for me.
my code
private void QueryTask_ExecuteCompleted(object sender, ESRI.ArcGIS.Client.Tasks.QueryEventArgs args)
 // Clear previous results
 GraphicsLayer graphicsLayer = mainMap.Layers["QueryGraphicsLayer"] as GraphicsLayer;
 graphicsLayer.ClearGraphics();
 // Check for new results
 FeatureSet featureSet = args.FeatureSet;
 if (featureSet.Features.Count > 0)
  // Add results to map
  foreach (Graphic resultFeature in featureSet.Features)
   resultFeature.Symbol = QueryResultsMarkerSymbol;
   graphicsLayer.Graphics.Add(resultFeature);
   //zoom to some level if your layer is TiledMapServiceLayer
   TiledMapServiceLayer tiledLayer = mainMap.Layers["mainMapLayer"] as TiledMapServiceLayer;
   Lod lod = tiledLayer.TileInfo.Lods[5]; //zoom to 5 level
   double halfWidth = lod.Resolution * mainMap.ActualWidth / 2;
   double halfHeight = lod.Resolution * mainMap.ActualHeight / 2;
   ESRI.ArcGIS.Client.Geometry.MapPoint newMapPoint = (MapPoint)resultFeature.Geometry;
   Envelope newExtent = new Envelope(newMapPoint.X - halfWidth, newMapPoint.Y - halfHeight, newMapPoint.X + halfWidth, newMapPoint.Y + halfHeight);
   mainMap.ZoomTo(newExtent); //thanks for bb1769
 else
  MessageBox.Show("No features found");
