map service don't show all records
3775
09-21-2014 12:48 AM
yousofothman
I have  this map service
http://84.235.15.69:8399/arcgis/rest/services/Expr_Operational/MapServer
I use this service on my web application, this is the link of my application http://84.235.15.69:7485//AlQassim_Explorer/
the problem that
the PARCELS_POL layer has about 170000 records. and it display only 500 record  i try to solve it from mywebservice.mapserver.cfg and change the max record to 170000 but it make the application very heavy on loading. can you help me for how to load all these record without effecting on its loading
DominiqueBroux
Esri Frequent Contributor
Silverlight ArcGIS API doesn't support loading 170000 features in memory without performance issues.
ArcGISDynamicMapServiceLayer has not this limitation since the server sends an image instead of features.
So I suggest you try displaying your service as an ArcGISDynamicMapServiceLayer at small scale and as featurelayer at large scale (by setting the MinimumResolution or MaximumResolution for these layers).
DominiqueBroux
yousofothman
thnak you very much for replay it help me
