Map Resolution in Silverlight print
2538
05-18-2011 09:54 PM
vamsibande
Hi ,
I have a requirment where i have to print a map and some grids around it .I have achieved this with the simple printing techniques available in silverlight .Now the problem is that the map shows me the exact screen replica of map (that is with the polylines as steps).But my requirment is to print the map with smooth lines .I have printed using the ArcMap and the map comes out with smooth edges even when the mxd shows distorted lines on the screen.
I am not able to achieve this quality in web print of the map.I have tried setting the antialiasing effect on the mxd but with no luck.
Any kind of help on this  would be greatly  appricated .
Hoping to find a solution here.
Thank You,
DominiqueBroux
Esri Frequent Contributor
This thread http://forums.arcgis.com/threads/30865-Aliased-lines-in-Silverlight-printout is also talking about the same kind of issue.
