Map printing error, when map with legend or overview map is selected
1121
10-11-2012 12:51 PM
ChadBartman
All
I am having a problem with the print dialog. I can print the basic or default map, but when I select the map with legend or overview map I receive an error, unhandled win32 exception iexplore.exe 4400. has anyone else had this error?
V/r
Chad
DominiqueBroux
Esri Frequent Contributor
Did you get the latest version of the print sample (download)?
I had noticed this error after migrating to Silverlight 5 and it's supposed to be fixed in the version I posted end of August.
ChadBartman
dbroux
I was working with the older version, but I am now having issues with loading v5. This project was built using SL 4.0 will that cause a problem?
Chad
DominiqueBroux
Yes the lastest version of the printing sample is using SL 5.0 and ArcGIS API for SL 3.0.
As ArcGIS 3.0 supports SL4.0 as well, you should probably be able to use SL4.0 + ArcGIS3.0 with the sample but I never tested.
