Map Binding Problems
1353
10-05-2011 11:21 AM
jonataspovoas
I'm making a silverlight 4 MVVM solution, using the ArcGIS API for Silverlight, and I'm having troubles binding some map properties.
My code gets the data needed to configurate the map context from a WCF Service, and then populates the map properties via Binding. But when I applied the Bindings, the application has thrown error on the set properties.
<esri:Map Layers="{Binding Mapa.Layers, Mode=TwoWay}"
                      Extent="{Binding Mapa.Extent, Mode=TwoWay}"
                      MinimumResolution="{Binding Mapa.MinimumResolution, Mode=TwoWay}"
                      MaximumResolution="{Binding Mapa.MaximumResolution, Mode=TwoWay}"
                      ZoomFactor="{Binding Mapa.ZoomFactor, Mode=TwoWay}"
                      WrapAround="True"
                      Background="#FFC3D2E5"
                      IsLogoVisible="False"/>
I tried this on the View Model constructor, but it didn't work.
public AreaDeMapaViewModel()
            servico = new SAEB_AutenticacaoClient();
            Mapa = new Map() {
                               Extent = new Envelope(-53.0569726287059,
                                                     -31.3741342130775,
                                                     -19.830953377022,
                                                     -5.01880861572849),
                               MaximumResolution = 0.0202254185495574,
                               MinimumResolution = 0.00118973050291514,
                               ZoomFactor = 0.1
            AcaoConfiguraMapa = new Comando(ConfiguraMapa, (parametro) => true);
Is there anything wrong with my bindings, or does the Map Object created on the view not Support Data Bindings?
JenniferNery
Map.Extent, MinimumResolution, MaximumResolution are not DependencyProperties and therefore do not support Binding.
