KmlLayer does not display images
7957
13
01-21-2012 11:28 PM
NataliaEvsyuchenya
Hello!
I am try to add KmlLayer to the Map. I place kmz file at the  C:\inetpub\wwwroot\KML_TEST_FILES\. If unzip the my kmz file you can see:
[INDENT]<?xml version="1.0" encoding="UTF-8"?>
<kml xmlns="http://www.opengis.net/kml/2.2" xmlns:gx="http://www.google.com/kml/ext/2.2" xmlns:kml="http://www.opengis.net/kml/2.2" xmlns:atom="http://www.w3.org/2005/Atom">
<GroundOverlay>
<name>????????? ??? ????????</name>
<Icon>
  <href>files/4_9.jpg</href>
  <viewBoundScale>0.75</viewBoundScale>
</Icon>
<LatLonBox>
  <north>52.95165833333334</north>
  <south>52.70903611111112</south>
  <east>27.76611666666667</east>
  <west>27.37067500000001</west>
</LatLonBox>
</GroundOverlay>
</kml>
[/INDENT]
I add the following code to my page:
              [INDENT]  public MainPage()
   InitializeComponent();
                        Map.Layers.Add(new KmlLayer()
                                                              Url = new Uri("http://localhost/KML_TEST_FILES/radar.kmz"),
                                                              ID = "Kml layer"
[/INDENT]
There is no errors but image is not shown on the map. What's the problem?
DominiqueBroux
Esri Frequent Contributor
I could display image when I set for Basic Layer Url = "http://server.arcgisonline.com/ArcGIS/rest/services/ESRI_StreetMap_World_2D/MapServer" instead of "http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer". But why KmlLayer depends on Basic Layer?
That rings a bell.
The extent of the images is set with the geographical coordinates found in the KML file but this extent is not the right one when your map is using projected coordinates.
In fact, KML Groundoverlays don't support autoprojection to non geographic coordinates. It's identified as a possible future enhancement but not planned at this time.
It's probably possible to project the extent by yourself (not tested and probably not that easy though):
- go through the KML layer hierachy to find all ElementLayers
- for each ElementLayer, loop on the elements
- for each element, project the extent from Geographical coordinates to Mercator
Sorry I should have thought about that sooner.
JenniferNery
DominiqueBroux
Which ArcGIS SL version are you using?
Only the 2.3 version takes care of GroundOverlays.
Also does the file 'files/4_9.jpg' exist in the kmz file (after unzipping as you did)?
NataliaEvsyuchenya
I have the 2.3 version installed. And file "files/4_9.jpg" exists.
NataliaEvsyuchenya
Have you looked at this blog post: http://blogs.esri.com/Dev/blogs/silverlightwpf/archive/2009/08/24/Troubleshooting-blank-layers.aspx?
I run the Fiddler2, but there is no errors. You can see screenshot [ATTACH=CONFIG]11365[/ATTACH]. And also layer appears in the Map legend.
DominiqueBroux
Could you share the KMZ file so I can test with it?
Thanks
NataliaEvsyuchenya
Thanks
http://ge.tt/8Igs2hC?c
DominiqueBroux
Thanks for the link.
From my tests, it's working.  You can test it here with the KML Viewer using the version 2.3 of the API.
NataliaEvsyuchenya
Could you show your code, please. Maybe the problem that I use localhost? Do you have any ideas?
DominiqueBroux
The code is published here .
Localhost should not be the problem. Nevertheless feel free to test your program with this public Url : http://broux.dominique.free.fr/Silverlight/test/radar.kmz
No idea. Just double check that you are using the 2.3 final (version 2.3.0.746)
