Is there any print example that can be referenced for SL 4?
19281
71
07-14-2010 01:18 PM
weiliang
I try to incorporate the print feature into our website (with SL 4, and ESRI API 2.0). I used the following code, but it direct me to the print dialog box only. How can I make a print template (e.g., http://citizengis.chesterfield.gov/) to print the current map extent with some controls (e.g, scale bar) into a pdf. Is there any easy way to do so or I must create a WCF service?
PrintDocument doc = new PrintDocument();
doc.PrintPage += (s, e) =>
   e.PageVisual = MyMap
   e.HasMorePages = false;
doc.Print("Map");
Many thanks,
Wei
TedBrown
Lisa,
I would appreciate a copy of your code.
tbrown at lcra.org
Thanks in advance!
-ted
JaneChen
Lisa,
Your attached zip file appears to be invalid or corrupt. Can you please send me your entire print project? My sl 4 project needs this customized print function immediately. Thanks!
jane chen
[email protected]
Good afternoon, all!
I have finally compressed my project down enough to post it here!  Now included is a table of contents for the two dynamic layers on the map, based on the SOAP code from this thread:
http://forums.esri.com/Thread.asp?c=213&f=2455&t=289070
The code I built on is posted in the third, fourth, and fifth posts in the thread.
If you have any questions, please feel free to ask!
Lisa
SloaneWalker
I tried to download your sample, but the zip seems to be corrupted for me.  Can you send the sample to [email protected] ?
KrisStitt
Would you mind sending me a copy as well, the zip file seems to be corrupted for me.
[email protected]
Thanks in advance for the help!
-Kris
LisaChesley
Good morning, all!
The project has been mailed out.  My apologies, I was out on holiday until this morning.
Lisa
JimmyBrink
I have fired off the project to those that have requested it so far - hopefully you find it helpful!  If anyone else would like it, please give an email address and I'll send it.
Thanks!
Lisa
Lisa
Can you send a copy of your print application, [email protected]?
Jim
LisaChesley
Good morning, Jim!
I have emailed the project.
Thanks!
Lisa
RodWilmot
Hi Lisa,
Would you be some kind as to forward your project to me as well?
Thanks again,
Rod
Central Lake Ontario Conservation
LisaChesley
Good afternoon, Rod!
I'd be glad to - do you have an email address I can send the project to?
Thanks!
Lisa
BrianPangtay
Lisa,
Can you send me a copy of your project to [email protected]?
Thanks, Brian
