Is there any print example that can be referenced for SL 4?
19268
71
07-14-2010 01:18 PM
weiliang
I try to incorporate the print feature into our website (with SL 4, and ESRI API 2.0). I used the following code, but it direct me to the print dialog box only. How can I make a print template (e.g., http://citizengis.chesterfield.gov/) to print the current map extent with some controls (e.g, scale bar) into a pdf. Is there any easy way to do so or I must create a WCF service?
PrintDocument doc = new PrintDocument();
doc.PrintPage += (s, e) =>
   e.PageVisual = MyMap
   e.HasMorePages = false;
doc.Print("Map");
Many thanks,
Wei
JeffSauder
Hi Lisa,
I did not get your email, my organization blocks .zip files and that is probably why.  Would you mind sending the code to [email protected]
Jeff
LisaChesley
Good afternoon, Jeff!
I just noticed that myself - the bounceback email ended up in my spam folder, so I didn't see it until this morning.  I have resent the project using a large email attachment tool which doesn't actually email you the attachment, but merely a link to the attachment which resides on our servers.  Hopefully that will pass your company filters, but if it doesn't, please let me know (at [email protected]) and I will send you the code unzipped.
Thanks, and have a great day!
Lisa
AlexanderOvsyankin
In the meantime, I'd be happy to email the project to anyone who'd like to see it.  Just post back with an email address that I can reach you at, and whether you'd like .zip or .rar.
Thanks!
Lisa
Hello Lisa,
Could you, please, send me your code sample at [email protected]? Thank you very much!
Rgds, Alex
LisaChesley
Good afternoon, James and Alex!
Your projects are in the mail. 🙂
Thanks!
Lisa
BrianBorg
Can some one send me the projects on [email protected] please?
Regards
JohnPalmbach
Hi Lisa,
Thanks for your community support.  Could you send your example to me as well?
[email protected]
-John
MartenLiebster
Lisa,
Thanks for sharing your code (grabbed it from the other thread)!
Looks like the process essentially is to:
1) create a smaller (dimension wise) map
2) match the extent
3) copy the various layers
4) print
Is this correct?
Thanks again.
TonyAlmeida
MVP Regular Contributor
wliang1 i am very interested on how your "Search" tool works, would you mind sharing that code?
Lisa could you send me the print code as well?    [email protected]
Thanks.
LisaChesley
Good morning, all!
@Akilly, John, Brian - your projects are in the mail!  My apologies for the delay - yesterday was a holiday up here. 🙂
@Martin - yes, that is correct.  The reason I am creating a reasonably small map is that the user needs to be able to view the entire print sample on their screen - if they can't, the area they don't see will appear cut off on their printout.  This is a problem, as many of my target users only have 1024x768 resolution, but the 'resolution' for a standard page is 816 x 1056 (reversed if they print in landscape).  It's tricky to get exactly what they want without leaving a lot of whitespace on the page.  If you try to print on larger pages, I imagine that you'd run into much the same problem.
Thank you all for your kind words and acknowledgements - I've gleaned much useful information from these forums, it's nice to be able to give back. 🙂
Lisa
LisaChesley
Good afternoon, all!
I have finally compressed my project down enough to post it here!  Now included is a table of contents for the two dynamic layers on the map, based on the SOAP code from this thread:
http://forums.esri.com/Thread.asp?c=213&f=2455&t=289070
The code I built on is posted in the third, fourth, and fifth posts in the thread.
If you have any questions, please feel free to ask!
Lisa
