Invalid value for parameter
1093
07-05-2010 06:38 AM
AriRaimundo
Hi guys,
I'm trying to consume a geoprocessing service that I've published in ArcGIS Server 9.3.1 (SP1) that contains an input parameter of type GPFeatureRecordSetLayer. This parameter was created in ArcCatalog using a schema-less FeatureSet.
My client application uses Geoprocessor class of ArcGIS API for Microsoft Silverlight/WPF just like the sample "Clip_Features". I first tried to consume using Silverlight without success and then I tried with web interface but I got the same error (Invalid value for parameter X).
Is there any known issues of this API using schema-less parameters?
See below parameter that I'm trying to pass through web interface.
    "geometryType" : "esriGeometryPolygon",
    "spatialReference" : {"wkid" : 31984},
    "features" :
        "geometry" :
     "rings" :
                  [739374.29,8853590.48],
                  [742721.27,8853590.48],
                  [742721.27,8857347.57],
                  [739374.29,8857347.57],
PS: I'm using ArcGIS API For Microsoft Silverlight/WPF version 2.0 Beta.
Thanks in advance.
Ari C. Raimundo
Application Developer
Curitiba-PR-Brazil
dotMorten_esri
Esri Notable Contributor
Since you are experiencing the same issue from the web interface, the issue is with your GP REST service and not the API. I suggest you ask in the REST and/or server forums: http://forums.arcgis.com/forums/11-ArcGIS-Server-REST-API
AriRaimundo
Thanks Morten.
Ari C. Raimundo
Curitiba-PR-Brazil
