Invalid Spatial Reference When MapLayer Changed to another Layer
1445
09-14-2010 11:32 PM
AnurithaPathireddy
When I change first Layer for Map( Previously it was set the First Layer as ArcGISDynamicMapLayer.)
to another Dynamic Map layer of Different Coordinate System It is throwing exception... Invalid Spatial Reference,SpatialReference Must match Map's Spatialreference....
getting the StackTrace as...
at ESRI.ArcGIS.Client.Map.checkSpatialReference(Geometry value)
   at ESRI.ArcGIS.Client.Map.panTo(Geometry geometry, Boolean skipAnimation)
   at ESRI.ArcGIS.Client.Map.PanTo(Geometry geometry)
   at ESRI.ArcGIS.Client.Toolkit.OverviewMap.UpdateOVMap()
   at ESRI.ArcGIS.Client.Toolkit.OverviewMap.UpdateOVMap(Object sender, ExtentEventArgs e)
   at System.EventHandler`1.Invoke(Object sender, TEventArgs e)
   at ESRI.ArcGIS.Client.Map.raiseExtentChanged()
   at ESRI.ArcGIS.Client.Map.<Map_SizeChanged>b__7()
   at ESRI.ArcGIS.Client.ThrottleTimer.<.ctor>b__1(Object s, EventArgs e)
   at MS.Internal.CoreInvokeHandler.InvokeEventHandler(Int32 typeIndex, Delegate handlerDelegate, Object sender, Object args)
   at MS.Internal.JoltHelper.FireEvent(IntPtr unmanagedObj, IntPtr unmanagedObjArgs, Int32 argsTypeIndex, String eventName)
Any help Please.......
Anuritha
JenniferNery
